Sound output
Discussion in 'Home Cinema Buying & Building' started by gskMike, Aug 17, 2005.
  1. gskMike
    gskMike
    I currently have a Samsung PS42D5HX 42" plasma, with a sky+ box
    Im now looking into buying a dvd player and surround sound package.
    I understand that if i buy an all in 1 package then the audio o/p from the dvd will goto the surround speakers, but will it also work when watching the sky+?
    If not can you buy a separate amp which will take inputs from both the dvd and the sky+ box??
    Thanks for any help
  2. GER103
    GER103
    u can use optical out from sky box to dvd surround sound amp and receive 5.1 sound on sky movies 1,2,3 and prologic on most others. I have a jvc ts5 from empiredirect and it is great! p.s what is the pic like on the samsung on sky? as i am receiving mine in one week, hoping it is ok?
