Sound output from Freeview box?
Discussion in 'Freeview & YouView' started by LCD User, Sep 15, 2005.
  1. LCD User
    LCD User
    Is there a big difference between sound through gold SCART RGB from the freeview box to the audio out on my AVR amp instead of using the digital audio out on the freeview box to coaxil on the AVR amp?
  2. Paul Shirley
    Paul Shirley
    Sep 27, 2004
    1,354
    63
    +174
    No difference I can detect on my iPlayer. Without knowing which box are you're using there's not much to say, for current broadcasts you'll only get stereo or prologic surround so sterero is good enough and only the actual stereo output quality should matter.
  3. LCD User
    LCD User
    Thanks,
    its a Thomson Frewview can;t remember the model number but it is the one able to receive top up TV.
  4. MartinImber
    MartinImber
    Apr 5, 2001
    3,854
    71
    Worcester
    +21
    Definite improvement with a Pace Twin and digital optical
