Sound Options
Discussion in 'Plasma TVs Forum' started by bluevortex, Feb 13, 2005.
  1. bluevortex
    bluevortex
    Feb 6, 2005
    1,927
    +80
    Got a 42" panasonic with toshiba home cinema system on the way.
    package includes composite/s video/component video board.
    Wanted to check i had everything needed to get sky and dvd working straight away on arrival.
    using scart to vga (i think) for sky but my question is will i be able to use the the surround sound system for all inputs to screen as there are no speakers with plasma? All the speakers seem to hook straight into the dvd player so how does that wrok for sound on sky tv?
    Apolagies if im being completely stupid - new to this technology
  2. Piers
    Piers
    Dec 11, 2002
    1,995
    Cheshire
    +230
    Scart to VGA is the best bet for Sky (I am assuming you have got a scart to VGA converter box). If Sky+ then you can connect the optical digital output to the home cinema system, if it is a non Sky+, Sky box, then red and white audio outs from the converter to the home cinema sytem.
  3. bluevortex
    bluevortex
    Feb 6, 2005
    1,927
    +80
    panic over then. thanks for your quick reply. yes its boring normal sky tv
    I ordered the scart to VGA from AV sales (£80 1.5m) dont remember anything about a converter box but im sure this the same thing you mention in your thread.
    Am i right in saying this would work with xbox plugged into sky box also?
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    your sky box should have red and white phonos and these can connect direct to Home cinema system analogue input (assuming it has one) SHOULD do
  5. bluevortex
    bluevortex
    Feb 6, 2005
    1,927
    +80
    im sure it does. theres a fair range of inputs on it. does that mean the dvd always has to be on when watching plasma?
    Are the speakers for the panasonic any good and are they worth the £300?
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    not worth £300 and yes if you want sound DVD on
