sound on telewest cable
Discussion in 'Cable TV & Virgin Media TV' started by pat clancy, Jul 2, 2002.
  1. pat clancy
    pat clancy
    Sep 10, 2000
    1,843
    LONDON
    +31
    i have digital cable with telewest,the radio sounds terrible,i was wondering if they compress the sound,can anyone shed light on this,i dont even think its stereo,i can never get pro logic from the tv on digital when watching movies,analogue is fine though,so much for digital tv
  2. Dangerous
    Dangerous
    Hello Pat
    The sound on NTL cable (Digital) which I think is the same as Telewest is not stereo as for the radio mine sounds ok.
    Dave
  3. tomson
    tomson
    Jul 19, 2000
    1,959
    Berk'amsted
    +186
    The sound on my Telewest is fine - some channels are better than others but thats due to the output from the channels themselves.
    Your sound should definitely be in stereo tho.
    You should get them to send an engineer out as it must be the way your digibox is setup in the service menu.
  4. Guest
    NTL Digital is very much Stereo......... If you ain;t getting it, your system isn't working right.
  5. stranger
    stranger
    yes ntl digital is stereo run it through your vcr and stereo should light up (but not nicam) some one posted that it's only through scart but i get it through the phonos too.
  6. Dangerous
    Dangerous
    Pat
    Sorry about the duff info, I have checked through my vcr and it does show stereo but strangely the tv is not indicating stereo.I have to say it certainly is not the quality that can be had on terrestrial i.e nicam, it sounds severely compressed.
    Dave
    PS Stranger thanks for the tip on checking for stereo.
  7. pat clancy
    pat clancy
    Sep 10, 2000
    1,843
    LONDON
    +31
    thanks for the replys,why no nicam stereo then,so i can forget about getting 5.1 with telewest,so do we agree that the sound is compressed,i wonder what bitrate they use,i believe the bbc use 180kbps on digital radio,i might be wrong on this. so the reason i cant get prologic is because telewest dont broadcast nicam stereo,is that right?
  8. Starburst
    Starburst
    Jul 13, 2000
    17,846
    Ilkeston
    +975
    Dolby Prologic can be carried on any stereo format, nicam (Terrestrial) or mpeg2(Digital cable/satellite).
    As long as the STB's audio output is sent to a ProLogic amp/TV via the scart cable or twin phonos AND the program has a ProLogic soundtrack then you'll get it.
