sound meter
Discussion in 'Subwoofers' started by jang150, Apr 14, 2004.
  1. jang150
    jang150
    i have purchased a sound pressure meter from cpc components having realised that it is set only to A weighting with no option to change it to C. Can i still balance my speaker channels or is it not possible with A weighting?
    Any help would be appreciated
  2. Ettepet
    Ettepet
    Feb 7, 2003
    739
    The Netherlands
    +19
    There is a table, but I'm not sure if your current range will cover all frequencies. I'm in a hurry at the moment... ;)
  3. Nimby
    Nimby
    Jan 27, 2004
    9,204
    The Danish Bacon Factory
    +670
  4. Ettepet
    Ettepet
    Feb 7, 2003
    739
    The Netherlands
    +19
    You see it is possible, but you need some hefty adjustments in the lower frequency regions. (48dB at 16Hz; 36dB at 32Hz)
  5. jang150
    jang150
    thanks alot for the help but have just realised that my yamaha dsp e800 processor hasn't got a subwoofer test tone. I think i will have to buy a calibration disc unless you guys can suggest a way round this?
  6. Ettepet
    Ettepet
    Feb 7, 2003
    739
    The Netherlands
    +19
    If you have a cd burner you can make your own one, easily. You could also choose to play test-tones on your PC, if you've got a good-quality connection through your soundcard or other.
    If you plan to burn your own cd there are plenty of tips or links on this forum (use search). ;)
  7. Maninblack
    Maninblack
    Sep 24, 2002
    458
    +17
    I think I have the same item, is it useless!! Id rather know before I jump all over it!
  8. cosmic023
    cosmic023
    Feb 15, 2003
    1,375
    48
    Somerset
    +88
    Try Here.....
    Main Page
    Test Tones Download
    Lot's of MP3 tones to download, and then burn to CD. I downloaded all of 'em and burnt 'em over two CDR's.
    I've also got a copy of AVIA as well, which is good for setting up you AV system.
    I hope this helps ??
    Cosmic023
  9. jang150
    jang150
    yes very helpful. All i need now is Avia to balance all my channnels.
  10. cosmic023
    cosmic023
    Feb 15, 2003
    1,375
    48
    Somerset
    +88
    Try the Powerbuy Forums for the Avia Disc
    It's where i got my copy, a disc that will keep you occupied for hours and tweak your AV kit to the max.
  11. mudan
    mudan
    Nov 26, 2001
    225
    Solihull
    +18
    jang150, use the test tones that come with the THX Optimiser - often found on quite a few discs e.g. Star Wars.
    I use the D.V.E (Digital Video Essentials) DVD.
  12. cosmic023
    cosmic023
    Feb 15, 2003
    1,375
    48
    Somerset
    +88
