Sound level on 'Alien'
Discussion in 'Movie Forum' started by GearHead, Jan 11, 2002.
  1. GearHead
    GearHead
    Has anyone else noticed that the sound level has been recorded very low on this disk or is it just my copy ?
    To get a reasonably strong volume I normally set my Yamaha to about 35db below full output for most disks. Watching Alien last night, I had to turn the volume up quite considerably to -25db. I've not noticed any other disk quite this bad before.
    Allan
  2. PoochJD
    PoochJD
    Aug 28, 2000
    11,002
    Norwich
    +1,861
    Hi GearHead,
    Have you got the R2 or R1 editions?
    On my R2 edition, that came in the 4xDVD "Alien Series Boxed Set", the sound is fine.
    You may have a duff copy, in which case you ought to try getting it exchanged, if you can.
    Sorry I can't be of more help.
    Pooch
  3. mjn
    mjn
    May 24, 2001
    22,266
    Herts, England
    +10,122
    i also have the R2 boxset, and the sound is dine, no problems.
  4. Paul Young
    Paul Young
    I have Alien to but i have noticed when they are in the ventilation tubes on the bottom of the screen is see quick flashes of lines when switching to different scenes. I have the region 2 copy.
  5. Mike Dando
    Mike Dando
    I have the same problem with my Aliens R2.
    Watched it on Friday and was very disappointed with the sound.
    I thought my sub had packed up as the LFE output on my amp was going mad but I was hearing hardly anything.
    I bought Aliens 4 (R2) at the same and it sounds great.
    Mike.
  6. GearHead
    GearHead
    Thanks for the replies. Mines R2 but not from the boxset (if that makes a difference ?). I guess I'll have to borrrow a copy from someone and see how they compare.
    Allan
