Sound Lag
Discussion in 'Satellite TV, Sky TV & FreeSat' started by rosemanbridge, Nov 19, 2003.
  1. rosemanbridge
    rosemanbridge
    May 24, 2002
    257
    I have my Pioneer DBR-TF100 Freeview box connected to my Meridian 568 processor via the optical output. However, by the time the audio gets to the speakers there is a time lag of approx 1/2 second. Very annoying. Any ideas on how to rectify this??
  2. tman
    tman
    Jul 16, 2002
    1,080
    Hampshire, UK
    +162
    Good old lip-sync problems. You will see a fair bit of this on Freeview, some channels are better than others though.
    What you will need is a processor (receiver) that has the audio delay feature. This can generally be applied independantly to each input source. I'm not sure if the Meridian has this feature, but the mid/high range Denon's do for sure.
    Not many other A/V receivers do at the moment, but with the huge interest in Plasma/LCD screens (and the inherant lip-sync problems they bring with there display processing), audio delay will be commonplace within 12 months.
  3. rosemanbridge
    rosemanbridge
    May 24, 2002
    257
    The 568 does have lip- synch, but it only delays it in 1/2 second intervals. What I need is to speed it up! It is OK on some channels like you say. I take it there's nowt I can do about it then?
