Tried to watch Heroes on BBC HD last night using the chase play feature (both eps recording plus the prog after each ep - i missed the end last week due to the scheduling slip
) I started trying to watch the first ep at about 9.30. The sound was so broken up that it was unwatchable.
I checked the real time BBC HD and that was fine and then left it until the first ep had finished before trying to watch it but had the same problem.
I've checked the recording this morning and it seems fine so I'm guessing that you can't use chasing play on HD channels - is it just too much for the box?
Has anyone else found this? I've done a search on it but couldn't find anything so apologies if it's been posted before.
(I wasn't recording anything else at the same time on another channel by the way, just for info.)
Cheers,
Jason.
Cheers,
Jason.
