Sound is not surround
penno118
I have a Panasonic SA-pt850 home cinema system which is connected to my Samsung HD TV via a bog standard audio lead (white and red). Problem i have is that when watching TV the sound is not surround, all the same noise comes from all 5 speakers at the same time. Is this because of the lead i am using?
Will getting an optical lead from the cinema system to the TV do the trick?
Thanks in advance
Hawklord
Hi, You've probably got the system set to 5 channel stereo instead of prologic;) Not sure the tv will allow an optical connection to your amp.
TEKNICOLOURFOX
also, connecting digitally (coax or tos link) between tv and system wont give surround sound, not many (if any) programmes are broadcast with surround sound
penno118
Not sure if my audio lead is buggered, when i unplug the white lead it makes no difference, lose no sound just stays the same, all coming out of 5 speakers. Is that normal?
Broadz
You stereo system is set to play back exactly what it receives as input to all five speakers. So whether you had stereo, mono or any other kind of input is irrelevant. What you need to do is find out how to set the audio out to something other than mono.
so how can a stereo connection (2 channels) give true surround sound?
it can't. it can play the 2 channel (stereo) sound out of more than 1 pair of stereo speakers, but it isn't whats normally classed as surround
