sound interference problem
Discussion in 'General TV Discussions Forum' started by seth2, Feb 22, 2003.
  1. seth2
    seth2
    I've recently purchased a new Panasonic TX32PL1 and have a problem with interference on the sound (hissing, etc) from the built in speakers - at first I thought it was just poor reception form the aerial, but having investigated further it also occurs whilst playing any DVD via SCART connection and the noise even continues from the speakers if I mute the sound. It appears to be an intermitant problem although has carried on all afternoon today.
    Am I being stupid or do I need to go back to the suppliers and create hell?!
    Many Thanks
    Steve.
  2. Squirrel God
    Squirrel God
    Some TV speakers do make a little noise (like a 'sssshhhh') even with the volume very low when connected to sources like DVD players - this is normal but you should only be able to hear it if you put your ear up to the speaker.
    But if you're muting the speakers and can still hear the 'noise' then that doesn't sound right at all.
    I would unplug everything that's even remotely near the TV and move them all away from the TV. Then see if the 'noise' is still there. If it's not, then it means there is some interference from something so you can start putting things back one by one and hopefully deducing what is causing the problem. If the noise is still there when everything is unplugged, I would contact your dealer.
