sound help
plasticboy
i have a Samsung LE32R74BD 32" LCD TV and the sound is pretty awful.
i sorted this by connecting it to my pioneer djm600 which is connected to
a technics amp with two output speakers.
Im moving house so want something simpler. I dont know if i need an amp, an AV or home cinema? i cant use the technics amp as that is for the decks.
any info greatly appreciated as i dont want to buy the wrong thing! just need to get decent sound :)
MarkE19
If you just want 2 speakers beside the TV then all you need is a basic HiFi amp & speakers. the LCD TV will have stereo RCA/phono outputs that you plug into one of the amps inputs.
If you want more than 2 speakers then you can go the Home Cinema route, ie AV receiver plus speakers or an all-in-one system. However you will only get Dolby Pro Logic 2 matrix surround as TV signals are only stereo. You would however get 5.1 sound from DVD's.
Mark.
M
MikeFish
Dude, you're in the wrong forum. Go back to the main page and try asking in the All-in-one systems bit (it's the 5th from the top). The guys there will know more about the system you have asked for thoughts on.
