sound from speakers ,poweramp on ,3802 off query.
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by mick23, Jun 6, 2004.
  1. mick23
    mick23
    Mar 20, 2002
    801
    uk
    hi all yesterday watching sky ,using parasound a23+denon 3802, when finished watching ,turned 3802 completly of at socket, but left parasound on, noticed sometime later i was getting sound from the front speakers ,but tv volume was zero , sky digibox volume was low, bit suprised i was getting sound without the 3802 even being on, not sure if this is some kind of "loop"
    thank you
  2. karkus30
    karkus30
    Jul 29, 2002
    13,997
    +1,236
    Has the Parasound got a trigger or is it just a plain power amp? If its just a power amp, then switch this off before powering down your preamp/processor.
  3. mick23
    mick23
    Mar 20, 2002
    801
    uk
    thanks karcus
    parasound has a trigger but i do not use this as as far as i am aware denon 3802 has not got an input/output for trigger .
    tried today sky etc with a23 do not seem to be having the same problem thank you
