Sound fade-out in Stereo mode
Discussion in 'Blu-ray & DVD Players & Recorders' started by kev_gordon, Feb 14, 2002.
  1. kev_gordon
    kev_gordon
    I recently (just before Christmas) purchased a Sony DVP-S735 DVD player.
    As I have not yet got round to buying a surround amp and speakers, I'm currently using my Hi-Fi, or the TV only, for the sound in stereo.
    I have noticed that when playing almost all DVD's, at certain points the sound seems to fade or drop out a little. It seems like the voice channel is getting overwhelmed by other sounds - particularly in intensive action scenes. This is repeatable, i.e. if I go back to the same point in the film, the same sound fade out occurs. The sound does not go completely, it just mutes a little, but noticeably so.
    Surely, if I have set the DVD player to 'Surround Off' or 'TV Stereo' modes, this should not happen - but it does.
    Do you think that I have a fault with the player?
    Any help would be greatly appreciated.
  2. Geoffc10
    Geoffc10
    check in the sound menu of the player to make sure you have down mixed the sound from 5.1 to stereo. All should work ok then
  3. kev_gordon
    kev_gordon
    Thanks for your response. I should have mentioned that I had checked that and it is already set to stereo.
    Any other ideas anyone?
  4. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,572
    Somewhere in South Yorkshire
    +6,093
    Whenever you downmix a DD5.1 soundtrack into stereo, it will get compressed - ie the loud bits get quieter relative to the quite bits. There is no solution to this, other than to select the stereor/DPL soundtrack, if the disc has one. Otherwise, it's a DD amplifier needed methinks.
