Sound experts please!
Discussion in 'Blu-ray & DVD Players & Recorders' started by thefourthalien, Apr 25, 2016.
Tags:
  1. thefourthalien
    thefourthalien
    Dec 8, 2014
    13
    4
    Watford, UK
    Hi again peeps. My Sony BDP S370 blu-ray player has suddenly lost sound through the amp. Can hear sound through TV speaker... and tested optical lead on tivo - seems fine. Just seems that the digital output on discs, etc, has dropped out. Had the player many years. ..does this kind of thing happen? Any ideas?
  2. thefourthalien
    thefourthalien
    Dec 8, 2014
    13
    4
    Watford, UK
    I now think it is an issue with my Yamaha amp. Tried all the usual suspects - loose lead, accidental mute, etc. No luck. Its probably a very simple answer!
  3. ashenfie
    ashenfie
    Jul 31, 2008
    1,814
    116
    Northampton
    +524
    Can you get sound from any source, if yes then try a different cable and HDMI port
  4. JayCee
    JayCee
    Jan 20, 2004
    23,203
    Lanarkshire
    +2,483
    If you read the OP's post you'll see that he has sound on the Tv and has tried his optical lead on his Tivo so that rules out the leads.
    OP, go in to your Blueray player's audio settings and see what format the optical out is set to...if it's Dolby D try changing it to PCM.
    You haven't stated whether your amp is surround sound or just stereo.
  5. thefourthalien
    thefourthalien
    Dec 8, 2014
    13
    4
    Watford, UK
    Hi - yep, went to the Blu Ray's audio settings and tried PCM ...but will try again. The amp is surround (5.1). Many thanks for your response!
  6. JayCee
    JayCee
    Jan 20, 2004
    23,203
    Lanarkshire
    +2,483
    Is your amp "mapped" to the correct input?
  7. thefourthalien
    thefourthalien
    Dec 8, 2014
    13
    4
    Watford, UK
    Yes, tried all of that - its very strange because it 'should' be working. It is old though. Perhaps something blew (does that happen with Yamaha amps?! They seem so robust!)
  8. JayCee
    JayCee
    Jan 20, 2004
    23,203
    Lanarkshire
    +2,483
    I wouldn't suspect anythings blown if you've tried your optical lead from your Tivo into the same input.
    It could just be a software glitch, try removing the mains power from your player and amp overnight.
  9. thefourthalien
    thefourthalien
    Dec 8, 2014
    13
    4
    Watford, UK
    I thank that could be the next thing to try - had it unplugged one hour, but will try overnight . Thanks. Will let you know!
  10. skk3
    skk3
    Sep 16, 2005
    2,541
    Rushden, Northamptonshire
    +245
    Tenuous I know, but have you had a software update on the amp or player? This may have reset some settings...
  11. thefourthalien
    thefourthalien
    Dec 8, 2014
    13
    4
    Watford, UK
    The Blu-ray player updates automatically; I wonder if going back to an earlier software update might help? I'm pretty sure the fault is with the Blu-ray player
  12. skk3
    skk3
    Sep 16, 2005
    2,541
    +245
    Check Dolby Digital and DTS are set to on, worth a check...
