Sound drops out momentarily every 5 - 30 mins
justinh
I have an Aopen XC Cube PC (http://www.silentpcreview.com/article140-page1.html) running Windows XP SP1.
It has on-board Realtek 650 sound chip using the latest A3.56 drivers
I use WinDVD5 and I output SP-DIF digital via an co-ax/RCA socket. I successfully get DD and DTS without problem, except that the sound drops out on occasions for 1 to 2 seconds then comes back again. This is not on the DVD as it applies to all DVD's as far as I can see.
This occurs every 5 to 30 mins approx.
I can put in a Creative SB card which will probably fix the problem but this uses the one and only PCI card slot up so I would rather not.
PC has a SATA Samsung hard disk and Samsung DVD drive and a Sapphire 9600SE video card.
Anyone any ideas ?
Thanks in advance.
Justin
CrispyXUK
Have you done a virus check?
justinh
No, however I have rebuilt it completely and still have same problem so unlikely to have virus.
However will check tonight.
CrispyXUK
have you got the Remote Procedure Call Patch?
justinh
Hi CrispyXUK,
No - just XP SP1
Nervous about chucking all the post SP1 hotfixs on!
Which is RPC patch and why do you think that it is relevant to my problem?
Regards
Justin
