Sound drop out on Sky+ recordings
Discussion in 'Sky Digital TV Forum' started by scitech, Apr 17, 2005.
  1. scitech
    scitech
    Hi. Over the last two or three days I have found that while watching recordings from the last week I get the occasional spot of sound drop out on my unmodded Pace V2. Mostly it's repeatable in the same spot, sometimes not.
    I am using the RCA outputs into a surround amp and the channels it's happened on are varied - The Simpsons on Sky One, CSI on UK Living, The Core on Sky Movies etc. Weather these artifacts (Is artifacts the right word? Maybe anti-artifacts?) are occuring live I don't know because we hardly ever watch anything live anymore.
    I am aware of the problem with the Sky+ 160 boxes but that seem to be a problem with the DD output so it doesn't seem to apply here.
    I have tried a housekeeping but it has still happened to recordings made prior to the housekeeping but I haven't watched anything new yet to see if it's still happening.
    Does anyone have a clue?
    Thanks.
  2. HMHB
    HMHB
    Nov 11, 2001
    25,621
    Nottinghamshire
    +3,981
    I have drop outs on my Amstrad and they normally only occur on the UK channels. Most of these drop outs do not happen again if I rewind and play the same but again.
  3. GGTVBD
    GGTVBD
    Feb 5, 2004
    3,365
    Bradford, West Yorkshire.
    +323
    Early signs of HD problems. :( Not terminal though. :)
    A full reset (not planner rebuild) should sort it out. Don't forget you'll lose everything in the planner when you do this.
    A. Dork
  4. HMHB
    HMHB
    Nov 11, 2001
    25,621
    Nottinghamshire
    +3,981
    I forgot to mention that mine does it when I'm watching live as well as on recorded stuff, so could be a different problem to the original post.
