Sound delay on Plasma
Discussion in 'Plasma TVs' started by billysmith, Jun 11, 2005.
  1. billysmith
    billysmith
    Anyone help me with a sound delay problem on Philips plasma, particularly when receiving some Sky channels. DVD plays OK. Perhaps it is a connection problem. TV is linked to DVD (cinema surround) system and sky box through scart connectors.
  2. nheather
    nheather
    Oct 6, 2004
    15,403
    Horsham, West Sussex
    +4,553
    Before blaming your connection or the plasma you should know that it is more than likely to be Sky itself.
    Sky is known for problems with sound delay although I must say that it is getting better.
    If you are suffering these symptoms:
    (i) Sound is delayed (i.e. behind the picture)
    (ii) Doesn't happen all the time and not on all the channels
    Then I'm 90% sure it is a Sky problem.
    However, if you are finding that the sound is ahead of the picture and happens all the time on all channels then it is likely you are seeing a lip-sync problem which you can fix (if using a seperate AV Amp) by either using the Amp's delay function (if it has one) or using an external delay (such as the Felston).
    However, from what you have said I think you are seeing the former (down to Sky) and there is not a lot you can do about it.
    Cheers,
    Nigel
  3. Mep
    Mep
    Dec 25, 2004
    9,579
    Surrey
    +474
    try a search here for 'lip sync' you'll get more info than you you can shake a stick at! (whatever that means)
