Question Sound cutting in and out via ARC
ets5048
I am just getting set up with an existing speaker system in my new condo. Have arranged for the following setup:
TV: LG 65UH6030
AV: Sony STR-DH550
Right now, I have the TV going into the receiver via ARC (audio return channel). My cable box is feeding through the receiver (also via HDMI), and the sound has no issues whatsoever. However, when I use the smart TV apps (Netflix, Amazon PRIME, etc.) the sound cuts in and out frequently (1 second cutout every 30-45 seconds).
Any advice? Unfortunately, I cannot use an optical cable, as the single HDMI cable already runs nicely through the walls.
The Sony STR-DH550 was refurbished. My feeling, however, is that it is a setting issue, as sometimes I can change the A/V modes and get the issue to stop. But then it recurs every time I start a new show on Netflix.
Violator
Is your TV network connection wireless or wired? When the sound cuts out, does the picture freeze/jump?
ets5048
It is wireless, however it is only the sound cutting. I've troubleshooted by using the TV speakers and it's clearly the reciever.
Violator
You mentioned your existing cable runs through the wall. Is it possible to try a different cable (not through the wall) as a quick test?
ets5048
Yes, and actually I have. It's re-affirmed by the fact that the cable does function well when passing across my cable box.
The issue seems to be a combination of the apps (Netflix, Amazon) outputting to the receiver. I just can't crack it.
ets5048
Any other thoughts @Violator ? I am starting to maybe question the refurbishing. The answer honestly seems to be powering the device on/off and going back and forth through the DTS settings. Eventually it stops after I sit there and play with said settings. Unless I am missing something entirely?
Violator
First off, is it possible to run a lan cable to the tv?
ets5048
Are you saying Ethernet, @Violator ? That'd be tricky, as the modem is situated upstairs (and the TV downstairs). I am not sure that I can blame the stream. It is clearly the audio only that cuts out.
Violator
It was more a quick test if possible to rule out wireless issues.
You now say fiddling with the dts settings helps? What settings exactly?
ets5048
I'm talking about switching from AFD, 2CH, MULTI CH, as well as from PLII Movie, HD-D.C.S., etc.
ets5048
Welp, problem solved. I returned the Sony STR-DH550. I ruled out the refurbishing being the issue by buying a brand new system and trying it out. Same issue, so that too was returned.
My new Yamaha RX-V379 (last year's model and still sold on Amazon) allows for seamless ARC communication. Very pleased. In addition, this receiver allows me to watch cable TV while listening to music from the AV channel... big plus!
Violator
I believe there are varying standards for ARC across different manufacturers, it is often a pain to get to work correctly, if at all.
Samsung S95B QD OLED Review - A Quantum Leap for OLED!
