JustEd
I have a 50" Panasonic Plasma TV. The sound cuts in and out constantly. I'll get a second and a half of sound, then a second and a half of no sound. It is constant, and started suddenly.
The remote is also malfunctioning. All I can do is turn the TV on and off, and change the screen format, although that is limited as well.. I can't change input, use volume or mute, etc. The batteries in the remote are new.
I don't know if the two are related, but suspect that perhaps they are because they both started at the same time.
