sound connection to plasma
Discussion in 'Plasma TVs Forum' started by andysup2004, Jan 13, 2005.
  1. andysup2004
    andysup2004
    i have bought the panny viera 42 and the panny scht 520 5.1 and would like to know how to connect it to my plasma for the best sound and what cables to buy at reasonable prices as my wife will go nuts if i spend much more as i told her everything was all in when i bought plasma :lease:
  2. SNICK
    SNICK
    Feb 4, 2001
    793
    28
    UK
    +29
    As you have bought an 'all in one' home cinema set up - I guess most of your inputs will go via this - as for the best sound - this is limited to where you position the speakers, the type of cable you use etc etc - might be worth checking the 'all in one' forum for this...
  3. wicket
    wicket
    Nov 23, 2004
    493
    Middlesbrough
    +10
    If your dvd player has component outputs, connect this way. If not connect via a RGB scart this gives you the next best picture.
  4. Ymegod
    Ymegod
    Nov 14, 2004
    175
    Bromley, Kent
    I may be wrong, and I suspect I am, but I thought that Andy was asking for the best source of audio for his plasma as opposed to the positioning of speakers etc.
    Wicket mentions connecting using component leads but I don`t think these leads carry audio do they ?
    I would also like to know the best source for audio to a plasma bearing in mind that it will be used as a television for all to use as opposed to a toy for me. I suspect it will be the Sky STB as most of our viewing is done thru this.
