Sound Card
Discussion in 'PC Gaming & Rigs' started by Jon, Jun 28, 2004.
  1. Jon
    Jon
    I am not sure if this is in the correct place, but here goes. I want to connect my PC up to my HC system and put all my CD's onto the pc and use it as a Juke box, the only problem is that the quality is nowhere near as good as my Pioneer DV757ai, is there a sound card that will give a really good sound quality when used in this way or am I stuck using my dvd player to play CD's? Many thanks for your help!!
    jon
  2. aliflack
    aliflack
    Mar 19, 2004
    238
    16
    Soundblaster Audigy 2 my friend - superb!
    even turns your dvd-rom drive into a fully functional dvd-audio player :thumbsup:
  3. Jon
    Jon
    Cheers Mate! How does it compare to high quality CD players, have you compared it to a CD player?
    jon
  4. Iain Shields
    Iain Shields
    Oct 19, 2001
    786
    N.Ireland
    +3
    Hi mate,
    You might have better luck posting in the Computer Hardware section further down the main page... Certainly try doing a search for sound cards in there as there is plenty of good info to be had :smashin:
    That's not taking away from aliflack suggestion of the Soundblaster Audigy 2 though, it's a very nice card indeed with plenty of owners here.
    Regards,
    Iain.
  5. The Dude
    The Dude
    May 21, 2004
    5,132
    Beverley, East Yorkshire
    +1,405
    The sounblaster is good, but from the reviews i've seen is not the best for high quality sound..
    I've got an Maudio 2496, which is excellent ( DAC sounds better than my old Musical Fidelity XDAC ) and the digital output is just superb..
    The Lynx cards also get good mention round here, although they are more expensive..
    RME is worth a look too, but don't know them well myself..
    For ripping CDs you want to download EAC ( Exact Audio Copy )
    the best HQ ripping software there is, bar none. ( and freeware too )
  6. Jon
    Jon
    Cheers Guys!
    Jon
  7. Garrett
    Garrett
    Apr 21, 2001
    33,101
    2
    167
    The best thief you’ll never see.
    +4,363
    Jon before you go starting an other thread on the same subject ask a moderator on this forum to move it for you. Starting twin theads is fround upon. ;)
  8. Jon
    Jon
    Sorry! I didnt realise you could move it! If you want to move this one and delete the new one then thats fine by me!
    Jon
