Sound Card with Optical out
Discussion in 'Computer Components' started by Comer, Jan 7, 2002.
  1. Comer
    Comer
    Sep 21, 2001
    1,390
    Ireland
    +86
    I have the fortissimo II sound card and have problems with stuttering. So if anyone could recommend an alternative sound card (that will not break the bank) with optical out I'd be most grateful. Also if you know where this card can be purchased online, perhaps you could include details of this
    Conor
  2. Jenz
    Jenz
  3. Comer
    Comer
    Sep 21, 2001
    1,390
    Ireland
    +86
    Thanks Jenz
    But after much experimentation last weekend I have discovered that it's the projector (Toshiba MT3) using the RGB input that's causing the jerky motion.
    Conor
