Sound card trouble
Discussion in 'Computer Components' started by Gibson76, Jan 2, 2005.
  1. Gibson76
    Gibson76
    Hi all, I just got my borken PC working and I have installed the sound drivers that i always have use off www.medion.co.uk but thy do not seem to be working.
    After reinstalling nothing happens, i still get no sound. I have tried nearly all the drivers on there and I have come up with no results. Anybody know what has happend?
  2. Synchro
    Synchro
    Nov 14, 2004
    3,887
    Chester
    +476
    Suggest you try older driver.
    Check windows sound settings and also check any 3rd party sound software setting you may be using.
    If no success try diff speakers (if possible).
    Also try a different soundcard (if possible).
  3. Gibson76
    Gibson76
    I think different sound card will be my best bet. I have tried countless drivers and still when I restart nothing happends. YOu think it could be a program conflict?
    I dont have much installed though, Steam (Half life 2) and avast anti virus.
    I am thinking this becasue steam is **** and it has had program conflicts before but oyu think it could stop sound working?
