Sound card recomendation.
Discussion in 'Computer Components' started by John Watts, Jun 17, 2003.
  1. John Watts
    John Watts
    Jan 27, 2001
    3,835
    71
    Leeds
    +80
    Hi all,
    Can anyone reccomend a good sound card with 6.1 for es/ex obviously with optical or coax outputs.
    Cheers,
    John.
  2. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,079
    UK.
    +2,571
    I would think most coax spdif out cards would be much the same.
    I'm using an old Aureal SQ1500 and it works a treat.
    The SB 4.1 and 5.1 both do spdif out via a 3.5mm mono jack to phono adapter, and work quite well apparently.
    Any spdif out card that does 5.1 will also do 6.1.
    There are a lot of very cheap cards out there, but I've not seen any reports of them. Ebuyer seem to have a few in stock by the looks of it.
    HTH
    Gary
  3. John Watts
    John Watts
    Jan 27, 2001
    3,835
    71
    Leeds
    +80
    Im sorry Gary what is spdif?
  4. StooMonster
    StooMonster
    Nov 20, 2002
    4,971
    Kent
    +314
    In this case it means digital coax output, to connect PC to digital decoder (e.g. Dolby Digital 5.1 or DTS).
    S/P-DIF means Sony/Phillips Digital InterFace, a now obsolete standard superseded by IEC 958; and can mean either digital 75ohm coax (RCA) or TOSlink (optical). It's purpose is a "consumer quality" connection from DVD/CD player to decoder/amp.
    StooMonster
  5. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,079
    UK.
    +2,571
    spdif is the Sony Philips Digital InterFace. :)
    it's the single output for digital sound, and is found on the back of DVD players, often with an optical output alongside it.
    HTH
    Gary.
  6. John Watts
    John Watts
    Jan 27, 2001
    3,835
    71
    Leeds
    +80
    I see thanks guys.
    So do any sound cards have coax or optical digital outputs? or even both?
    Cheers,
    John.
