sound card reccomendation
Discussion in 'Computer Components' started by Ayub, Oct 16, 2003.
  1. Ayub
    Ayub
    Oct 15, 2003
    6,610
    Bradford
    +607
    Hi, Me again could anyone point me in the right direction for a sound card which has optical.
    I dont care if its a non dancing no lights its for AV amp whch will decode the signal all i need is a encoder.
    Any suggestions?
    Thank you in advance
  2. Garrett
    Garrett
    Apr 21, 2001
    39,843
    2
    167
    The best thief you’ll never see.
    +6,514
    You could look through the specks here.
  3. GRees
    GRees
  4. Garrett
    Garrett
    Apr 21, 2001
    39,843
    2
    167
    +6,514
    Your link does not appear to be working. Yet if you enter it in the address it does.:confused:
    Try this again http://www.terratec.co.uk/
