Question Sound Card Question
Discussion in 'Computer Peripherals & Consumables' started by killie77, Apr 29, 2016.
Tags:
  1. killie77
    killie77
    Aug 19, 2007
    1,419
    Glasgow
    +134
    HI
    Recently purchse the HP Pavillion Mini. It has a 3.5mm jack on the back which i would like to connect to a Quad Vena amp through a digital input on the back of the Amp. I'm guessing the output from the PC is analogue its the Realtec HD card. Would i need a USB device to take the signal from analogue to digital in to the Amp ?. Apologies as i guess this has been asked before
    Ian
  2. EndlessWaves
    EndlessWaves
    Apr 7, 2008
    13,204
    Norfolk
    +2,339
    You do occasionally see combo sockets that'll take both a 3.5mm jack for analogue and a mini optical connector for S/PDIF. If it only says 3.5mm in the specs then it's analogue.
    An analogue to digital converter powered by USB probably does exist but it would be the worst option. Looking up the Quad Vena it has a direct USB input which is your best option if you're not using it for anything else. If you are, then I'd go for a USB external soundcard that provides a S/PDIF output.
  3. killie77
    killie77
    Aug 19, 2007
    1,419
    Glasgow
    +134
    Thanks for the reply. could I use a USB2 cable
    The kind you use for printers ?
    from the pc usb out their are 2 at the back of the HP mini both USB3
    Regards
    Ian
  4. killie77
    killie77
    Aug 19, 2007
    1,419
    Glasgow
    +134
    Hooked up the USB 2 cable from the PC to the Quad. It shows up in the Sound control panel of the PC so im able to use it for audio so long as I make it the default device.
    I also have an HDMI going out to the TV from the PC which I would like to keep for movies etc.
    Is their a way without going through control panel to choose one or the other on the fly.
    Ian
  5. EndlessWaves
    EndlessWaves
    Apr 7, 2008
    13,204
    Norfolk
    +2,339
    You should be able to right click on the sound icon on the task bar to bring up the playback devices screen.
  6. killie77
    killie77
    Aug 19, 2007
    1,419
    Glasgow
    +134
    Will give it a go.
  7. ChuckMountain
    ChuckMountain
    Oct 5, 2003
    6,021
    +1,164
    I use Audio Switcher which is great and allows a variety of ways of swapping audio inputs, including hot keys, task bar support. I keep my Headphones permanently attached to my PC and switch between those and the speakers with one mouse click.
    Audio Switcher
  8. killie77
    killie77
    Aug 19, 2007
    1,419
    Glasgow
    +134
    Thanks for the Heads Up
    Will download and give it a try
    Ian
