sound card for z5500
Discussion in 'Computer Components' started by supergeek, Jun 15, 2009.
  1. supergeek
    supergeek
    Sep 7, 2007
    1,224
    48
    everywhere
    +29
    need to be able to do at least dts and dolby surround (is there something else ive missed out?), for gaming and watchin HD movies..any ideas? was thinking of the asus xonar but am confused as some people say it does dts and some say it doesn't :confused:
    thanks :thumbsup:
  2. namuk
    namuk
    Oct 23, 2006
    22,187
    +4,332
  3. Sniper Ash6
    Sniper Ash6
    Jun 5, 2008
    27,845
    127.0.0.1
    +7,660
  4. supergeek
    supergeek
    Sep 7, 2007
    1,224
    48
    everywhere
    +29
    thanks for replying, that forte sound card is exactly the kind of one i wanted
    will ask away in the thread :thumbsup:
  5. Sniper Ash6
    Sniper Ash6
    Jun 5, 2008
    27,845
    127.0.0.1
    +7,660
    :thumbsup:
    no probs
  6. supergeek
    supergeek
    Sep 7, 2007
    1,224
    48
    everywhere
    +29
    needed to upgrade other parts of my pc so had to reduce sound card budget to around £80, anything around £80 similar to the forte that does DTS and 5.1 surround?
    or is it worth living on bread and water for a month and paying the extra for the forte? note if there's any alternatives it would be very useful if they worked in my spare pci express x16 slot :D
    thanks againnnnnn :thumbsup:
  7. Sniper Ash6
    Sniper Ash6
    Jun 5, 2008
    27,845
    127.0.0.1
    +7,660
    what outputs you looking for - optical, coax etc?
  8. namuk
    namuk
    Oct 23, 2006
    22,187
    +4,332
  9. supergeek
    supergeek
    Sep 7, 2007
    1,224
    48
    everywhere
    +29
  10. namuk
    namuk
    Oct 23, 2006
    22,187
    +4,332
    oh right Thought you new about Eax . Eax is hardware accelerated surround sound for enabled games OpenAl and Directsound (in vista you need to use ALchemy for Directsound) this takes stress off Cpu
    here is the EAX site, also at top you will see Eax Games list Creative Sound Blaster Sound Card Technology - X-Fi, EAX and OpenAL
    The creative card posted is the XFI this has Eax 5 Hd , on above site at top right there is a GO To, this has all info need to no there :)
    only problem with the posted creative card is the sdif out only supports 2 channel to use 6 channel you would need to use the 6ch input on back of pic you posted , from the specs reading on Creative site :rolleyes: also card does not come with an optical lead the card has no coax (your pic)
    if your not Bothered about EAX just get the Auzen X-Plosion 7.1 this card comes with a optical lead this must be there preferred choice and the card is coax also ..
    or the Zonar card not full EAX support but also has Digitel out not sure on win7 drivers though ..
    Computer hardware and software at amazing prices, available online - Scan.co.uk)
  11. supergeek
    supergeek
    Sep 7, 2007
    1,224
    48
    everywhere
    +29
    an optical cable is not a problem, i already have one of them :)
    im not too sure what you mean by "the sdif out only supports 2 channel to use 6 channel you would need to use the 6ch input on back of pic you posted"...does this mean if i connect via optical with the creative I won't get 6 channel? will i need to connect the green black and yellow wires to get 6 channel?
    main things i need are DTS (I have a few DTS music albums, 1080p movies) and 5.1 surround for gaming (so that i can hear people shooting behind me :D)
    :thumbsup:
  12. namuk
    namuk
    Oct 23, 2006
    22,187
    +4,332
    from what i read on the creative site for above card yes and you have need to use the green,black,yellow plugs .. i thought they would of sorted this due to the above cards auzen and asus can send 5.1/7.1 via coax or spdif (optical) there is an addon for the creative card to send 5.1 over digital but then that is more expense ..:(
  13. supergeek
    supergeek
    Sep 7, 2007
    1,224
    48
    everywhere
    +29
    true true :( which would you recommend then? want to get it ordered tonight :thumbsup:
  14. supergeek
    supergeek
    Sep 7, 2007
    1,224
    48
    everywhere
    +29
  15. namuk
    namuk
    Oct 23, 2006
    22,187
    +4,332
    the creative card is the same as the on i posted on overclockers only difference is that titanium has X-ram 64 mb some games use that to load in sounds so you get faster frames .. both are pci express 16x ..
    the asus is Pci i posted the pci express 16x version above but link not working:mad:
    here it is again Computer hardware and software at amazing prices, available online - Scan.co.uk)
    :thumbsup:
    Edit .. link not working but the card is there in sound section i.e Asus Xonar D2X Ultra Fidelity 7.1 PCI-E Sound Card at £83
  16. supergeek
    supergeek
    Sep 7, 2007
    1,224
    48
    everywhere
    +29
    ah nice, cool think i'll go for that one :) can we get free delivery from scan because we're registered on avforums? how does that work?
  17. namuk
    namuk
    Oct 23, 2006
    22,187
    +4,332
    nice one :smashin:
    yes you can link here mate .. AVForums Home
    you have enough posts :thumbsup:
  18. supergeek
    supergeek
    Sep 7, 2007
    1,224
    48
    everywhere
    +29
    wow thanks mate, will let you know how the card turns out :thumbsup:
