Sound card Digital output?
Discussion in 'Computer Components' started by faithless, Jul 29, 2001.
  1. faithless
    faithless
    ello :)
    I want to connect my Sound blaster live player 1024 to my av amp using the yellow minijack digital output.I have read that i need a MONO minijack to coaxial cable, is this correct?, if so where can i buy one online? I have searched but i cannot find one!
    thx
    Hope you can help
  2. titan
    titan
    OK, i have one of these cards and use the digital output.
    Personally i made a cable myself as it is impossible to find a 75ohm cable to suit.
    What you need is a length of 75ohm cable a good quality mini mono headphone jack and a good quality rca connector oh and a soldering iron.
    i assume you have used a soldering iron before so simply strip and solder the inner core to the central clamp and the outer wires to the uoter clamp then all you do is crimp and yur away.
    that will give you a high quality digital speck 75ohm cable which you wont find anywhere else.
    if that sounds like to much work just go to tandy and buy a single mono nini jack to single rca cable it will do the job but its a bit tacky.
    hope this helps
    nathan
  3. Stuart Wright
    Stuart Wright
    AVForums Founder Staff Member
    Jan 24, 2000
    14,769
    7
    2
    167
    Birmingham, UK
    +10,673
    This is a home cinema computer question.
    Do a search for sound card and you should see plenty of related topics.
  4. jason t
    jason t
    Mar 4, 2001
    1,709
    48
    kent
    +38
    you will be able to buy a jack plug from maplins ,they have a web site but unfortunatley i cant remember it sorry
    jason
  5. Jeff
    Jeff
    Jul 13, 2000
    5,507
    Basingstoke
    +263
    Faithless,
    You just need a mono RCA to mini jack connector, then you can use a standard 75ohm digital coax cable. I have a spare 1, if you email me your address I'll send it to you.
    Jeff
  6. faithless
    faithless
    Thank you all :)
    My soldering skills are not up too much so i'll give that idea a miss :) thx though :)
    Jeff your a diamond :) will mail you now :)
    Oh soz Spectre :) i put his in the general forum as i allready have my pc hooked up to my amp through my decoder card for dts/dd use.I want this cable so i can use my amps dac instead of my sblives so i can get the best out of my cdz and mp3z :)
    thank you all :)
