Sound Card Crackle via SPDIF
Discussion in 'Computer Components' started by MikeTV, Aug 7, 2004.
  1. MikeTV
    MikeTV
    Feb 1, 2003
    7,782
    Ealing, London
    +842
    To cut a long story short, I have had to reinstall Windows XP. Everything is now back to normal except that my Philips Acoustic Edge sound card crackles frequently when listening to sound via the SPDIF connection (it didn't used to).
    The card is on IRQ4, which is not being shared with any other devices. I have heard that it may be related to the ACPI power interface using DMA, and so I have tried switching off power management in the bios - but windows is still showing the ACPI device.
    (The reason for the reinstall was that I was trying solve another problem, and was trying a different hard disk driver - and managed to cause a blue screen of death. But I think the drive is installed correctly now and using the right drivers.)
    My only thoughts are to try changing the PCI slot of the sound card. I know I am definitely using the right sound card drivers.
    Any thoughts?
    Thanks,
    Mike.
