Sound but no picture or menu display DV-717
Discussion in 'Blu-ray & DVD Players & Recorders' started by stu270, Mar 17, 2006.
  1. stu270
    stu270
    Mar 17, 2006
    5
    Hi guys,
    I have just bought a second hand Pioneer DV-717. I have tried both the Scart and SVHS outs on the player, but get no picture at all. I think the previous owner used a projector. This there a way of being able to see a menu display to set to my equipment. Or a factory reset button? Please help. Thanks in advance.:lease:
  2. DVDANDY
    DVDANDY
    Feb 6, 2005
    116
    Corby
    i have a pioneer 868avi is there a pure audio button on the 717 as this is on the 868 avi and when on gives sound but no picture
    give it a try
  3. stu270
    stu270
    Mar 17, 2006
    5
    no there isn't. i think i need to change the picture settings in the menu, but nothing appears. thanks anyway.
  4. DVDANDY
    DVDANDY
    Feb 6, 2005
    116
    Corby
    just looked at the manual on pioneer website the only thing it says for no picture in the troubleshooting is connection not correct
  5. Hkan
    Hkan
    You might need to connect the DVD-player to the TV with a composit (the yellow one) cable to be able to see a OSD menu.
    The rear panel's video output switch setting is not correct.
    To reset the player you migth try this. Have the player turned off, press and hold the Stop button and at the same time press Standby / ON
  6. Drex
    Drex
    Feb 27, 2006
    627
    Basingstoke, Hampshire
    +19
    Stu270.............Have you got this problem sorted yet ?
    I have the same problem !
