mushtafa
Established Member
Is it possible to use the SPDIF optical output at the same time as the normal 3.5mm jack?
I've got the optical connected to my AV receiver which is working a treat, but I'm not getting anything from the normal front channel jack. - I want to keep my headphones plugged in for ease.
I've found the options in Windows 7, but can only select one default output device, Speakers OR SPDIF
