Sound Blaster Live 5.1OEM
Discussion in 'Computer Components' started by Comer, Oct 24, 2001.
  1. Comer
    Comer
    Sep 21, 2001
    1,384
    Ireland
    +85
    I am hoping that someone knows simething about this sound card. It seems very reasonably priced at £27
    Does this card have 5.1 channel out and if so is it DTS as well as Dolby Digital? Does it have coaxial/optical out or both.
    Conor
  2. Jeff
    Jeff
    Jul 13, 2000
    5,507
    Basingstoke
    +263
    Its fine, it has a digital mini jack out. You need a mono RCA to mini jack converter and a standard 75ohm digital coax cable.
    Jeff
  3. Comer
    Comer
    Sep 21, 2001
    1,384
    Ireland
    +85
    So it can not be used with an optical in on an amp?
    Conor
  4. Jeff
    Jeff
    Jul 13, 2000
    5,507
    Basingstoke
    +263
    No it can't, you can get coax - optical coverters but they cost about £70.
    Jeff
  5. cg999
    cg999
    Is there a sound card that has optical out and does not cost the earth?
    Conor
