Question Sound bar / base - limited space
Discussion in 'Soundbars, Soundplates & Soundbases' started by bunyboy, Feb 27, 2018.
    1. bunyboy
      bunyboy
      Dec 14, 2002
      1,239
      41
      LONDON
      +24
      Hi All,
      I have limited space but want to add a sound bar or sound base to improve the audio from my TV. The issue is the space it needs to go is 90cm wide and 27cm deep.
      This seems to narrow my options considerably. In fact, I've only found the Acoustic Energy AEGO Soundbar that will fit the space and is supposed to give a decent sound.
      Does anyone know of other options that might work?
      Thanks,
    2. samgamgee
      samgamgee
      Dec 30, 2008
      645
      +91
      I've got similar issues if a little larger space than you.
      I've considered maybe a soundbase in the shelf in the TV unit but I think you need space around these so may not be a good option.
    3. bunyboy
      bunyboy
      Dec 14, 2002
      1,239
      41
      LONDON
      +24
      I can't find a soundbase that will fit on my shelf anyway.. they all seem to be 30cm plus so no good for me.
    4. bunyboy
      bunyboy
      Dec 14, 2002
      1,239
      41
      LONDON
      +24
      I've seen the Samsung HWM360 is just over 90cm and I might be able to get away with it as long as it's under 91cm. It's going to be wider than the TV though.
      Anyone have that model or have other suggestions?
    5. Steve356
      Steve356
      Feb 6, 2017
      567
      Reading, UK
      +385
      I had a similar space problem for a bedroom TV. How about the Cambridge Audio TV5v2? This what I got after quite a bit of research. I've been very happy with it.
      TV5 (v2)
    6. bunyboy
      bunyboy
      Dec 14, 2002
      1,239
      41
      LONDON
      +24
      Yeah, I saw that. It looks great. But I've realised how big the sound bases are and I only have 27cm of depth on a shelf and none of less than 30cm.
    7. Steve356
      Steve356
      Feb 6, 2017
      567
      Reading, UK
      +385
      Just measured mine and the feet that the sound base sits on are about 25 cm long, so they would just fit on a 27 cm deep shelf. The front of the sound base would overhang a 27 cm deep shelf, but sometimes that can be a good thing in terms of dialogue projection.
    8. bunyboy
      bunyboy
      Dec 14, 2002
      1,239
      41
      LONDON
      +24
      That's interesting. Thanks for checking that. Does that include space behind for the power lead etc that stick out? That always seems to add a lot for me...
    9. Steve356
      Steve356
      Feb 6, 2017
      567
      Reading, UK
      +385
      Good question! I have the power lead and an optical cable (I use this rather than a HDMI lead on this particular system) and they do add about 5 cm to the depth. Therefore the total depth of the sound base is 33 cm plus 5 cm for cables (measured on the top of the unit), while the base sits on feet that are about 25 cm long. If your shelf is hard up against a wall, you would have a problem. The sound base itself needs a little room at the back anyway or the bass can become little muddy, especially at higher volumes.
    10. bunyboy
      bunyboy
      Dec 14, 2002
      1,239
      41
      LONDON
      +24
      It is indeed flat against a wall. So I'm out of luck. Smaller sound bars seem the only option.
    11. samgamgee
      samgamgee
      Dec 30, 2008
      645
      +91
      Do you think this would fit in a shelf unit with a PS4 and Sky Box on top?
    12. Steve356
      Steve356
      Feb 6, 2017
      567
      Reading, UK
      +385
      I measure the height of mine as 10.5 cm including the feet.
    13. bunyboy
      bunyboy
      Dec 14, 2002
      1,239
      41
      LONDON
      +24
      Ok, so I'm looking at a few soundbar options. Anyone have opinions on the following:
      - Acoustic Energy AEGO Soundbar
      - Samsung HWM360
      - Sony HTMT300
      - Panasonic SCHTB488
      They'll all fit on my shelf (the Samsung only just) and the Panasonic is the only one with HDMI and it's an 'Arc' HDMI, which could be helpful if it does what I think it does...
      Thoughts?
    14. samgamgee
      samgamgee
      Dec 30, 2008
      645
      +91
      The other issue is would I need space around it for the sound?
    15. Steve356
      Steve356
      Feb 6, 2017
      567
      Reading, UK
      +385
      Not sure I understand your question but the sound comes out of the front, plus there is a woofer on the underneath that needs to reflect against a solid surface. The feet on bottom provide the correct amount of room for the woofer to perform.
      Looking at your original question again, I don't think you would get great results putting a couple of boxes on top of the sound base. It really needs to have the TV resting on it (they are designed for this) or placed on a shelf directly above a TV. That way, the sound will appear to be from the screen. Too far away from the TV and you will likely get some odd results with localisation of the sound.
    16. samgamgee
      samgamgee
      Dec 30, 2008
      645
      +91
      Thanks Steve.. thats twice ive read that now. Soundbases are out then
    17. heavymetalmat
      heavymetalmat
      Apr 20, 2015
      129
      selby
      +40
      Why not look in the classifieds for an avr/amp and hook up some speakers?? I've used this set up for ages and works a treat
    18. Soundizer
      Soundizer
      Apr 4, 2017
      644
      67
      United Kingdom
      +322
      I am facing a similar dilemma.
      So far the Polk MagnifiMini seems to be the best option in terms of sound quality, hdmi arc and smallest foot print. There is a Video review here:
      Polk Magnifi Mini Soundbar Review
      It is £299 and includes a wireless Sub.
    19. Khazul
      Khazul
      Sep 10, 2017
      1,818
      3
      2
      116
      UK
      +647
      Might better with a small AVR and a compact speaker package.
    20. Blues Rock
      Blues Rock
      Jun 29, 2006
      694
      47
      Planet Earth
      +152
      You will get better sound from a set of stereo speakers and a stereo amp.
      Thats what I use
