Sound - Analogue to Digital
Discussion in 'Satellite TV, Sky TV & FreeSat' started by Borrower, Jan 3, 2005.
  1. Borrower
    Borrower
    I recently got a new Digital Surround Amp and found I have to use two separate connections to my VCR/DVD combi :- Analogue for VCR and digital for DVD.
    When I get my new Sky+ box installed I am intending to connect it to the amp with a digital connection (optical) but does this mean that I would only get sound from Channels that support Dolby Digital? Or is the Sky+ box clever enough to convert the signal and pipe it all down the optical connection??
    I realise I could connect the Phono connections as well as the Optical but then I would have to have two sources on the Amp and switch between them depending on what channel is being watched. IYSWIM
  2. KingOfGondor
    KingOfGondor
    Dec 30, 2004
    558
    28
    +25
    all goes down the optical whether it is DD5.1 or DD2.0 or DPL
  3. Borrower
    Borrower
    Cool, thanks.
