Sound Advice on a Sony KV-28LS35U Needed.
Discussion in 'Televisions' started by Garrett, Jul 6, 2003.
  1. Garrett
    Garrett
    Apr 21, 2001
    32,258
    2
    167
    The best thief you’ll never see.
    +4,200
    I have just switched on the TV and there is no sound from the set. It is not on mute mode. I went to the sections in the menu where you can alter the Treble, Bass, and Balance and they were all set to the far left so I moved them up to the middle but still no sound.
    This fault is on all channels.
    Any ideas what may be causing the loss of sound, and how to get it back?
  2. Garrett
    Garrett
    Apr 21, 2001
    32,258
    2
    167
    +4,200
    I forgot to say the volume is turned up as well.
  3. Squirrel God
    Squirrel God
    Are the speakers turned on in the "Detail Setup"?
  4. Garrett
    Garrett
    Apr 21, 2001
    32,258
    2
    167
    +4,200
    Thank for the reply. :smashin:
    I just went to the set and switched on to try and the sound was working fine.
    I think the speakers may have been switched off but I switch them on, but they still did not work earlier. I have no idea how all the settings got altered.:confused:
  5. Squirrel God
    Squirrel God
    No idea either Garrett. Did you have it unplugged from the socket for a while? If so, maybe everything got reset as a result.
  6. Garrett
    Garrett
    Apr 21, 2001
    32,258
    2
    167
    +4,200
    I had it switched of at the plug, same as un-plugged.
    I can’t understand having no sound though switching of then it coming on the next time.:eek: :confused:
  7. Squirrel God
    Squirrel God
    Well, keep an eye on it just in case but probably just a little glitch that never happens again :)
  8. HREAL
    HREAL
    I Know Why. But Dont Know How To Solve.
    When Yuou Go To "manual Presenting", You Must Change The Tv System To "i".
    At This Moment I Got The "b/g" And "d/k" System. "i" Cant Put The "i" Back.
    If Someone Knows, Please Help.
    I Was Reading Another Model Users Manual And The Manual Says To Reset The Tv On The Remote Control.
    But The Remote Control Of The Kv28ls35u Dont Have Reset.
  9. HREAL
    HREAL
  10. JayCee
    JayCee
    Jan 20, 2004
    20,030
    Lanarkshire
    +1,909
    HREAL...this thread is 4 yrs old.
    Please start a new thread and give the fault symptoms.
  11. fred the ted
    fred the ted
    I have the same problem in that the the 'TV sound' switches off for no reason.
    I happens about twice a year for no reason.
    It panics the wife though.
  12. HREAL
    HREAL
    but can you you please help me than.
    am just a beginner.
    I bought this for one month a go.
