Quantcast
Sound adapter for headset
GuitarGuy
I'm looking at getting a pair of senhiser pc360's right, so I've also looked and found a decent pc sound card. Now how do I hook it up to my ps3, both headset and mic, and is it possible to use dolby headphone for virtual 3d? Also is there any way to plug the in and out of the pc card and the ps3 mixer into a switch box so I can press a button and it changes over. Any help would be appreciated. Ps I really don't wanna break the bank here ive not got much left over after buying these parts.
GuitarGuy
Anyone?
Foster
You got a PC sound card for a PS3 even if you do get it set up it will need drivers which you can't get on the PS3
GuitarGuy
You've misunderstood me. I meant I've got a sound card for my pc. Now I need a device for my ps3 to connect the pc360's.
RottenFox
Pointless, and a waste of time and money.
Problems from the start, will the PC card decode the audio(to give 5.1), will you get anything other than stereo, will the pc soundcard, do a better job than a cheap £2 usb sound card connected to the PS3's usb, with mic and audio connections, which sounds crap, and performs just as badly.
If you google this kind of thing, you will see people have issues with it, and not a lot bother, TBH
To be blunt, you would be better off buying an amp/speakers, or surround system, or a mixamp/DSS and a set of cans, rather than bother with this.
Foster
Is the headset just 2 x 3.5mm jacks 1 for audio 1 for the mic
GuitarGuy
Yes it is. And the soundcard is a xonar Essenes st, extremely high quality sound card. I just want something cheap for my ps3 as well.
Foster
You can buy like £3 USB sound cards where you plug the mic jack into the USB and the AUDIO into the TV :p
GuitarGuy
Ok a bit more than that :L something where both plug in together would be nice, volume controls are on the headset so not essential.
Foster
There isn't anything else on the market :p
GuitarGuy
You're joking right....? :eek:
Foster
Nope only option really if you are using a PC headset for a console :p other than only other way is getting a headset made for the console like the turtle beaches :p
GuitarGuy
But that would mean compromising sound quality massively :( isn't there some kind of amp or something..... I don't mind spending up to maybe 40/50 quid?
paulst10
GuitarGuy
paulst10
GuitarGuy
paulst10 said:
They are £100 mate :(
You could look into the DSS unit as they are £40 but you need confirmation that you can connect the mic for use on a PS3.. I don't think it can do this but I have never tried it (something I forgot to do when I borrowed one for a few hours) :suicide:
Turtle Beach DSS 7.1 Dolby Surround Sound Processor | eBay
For 40 quid that would be perfect if it works with the mic, anyone know if it does?
EDIT: I could potentially leave my headphones plugged into that and use an optical switch between the ps3 and the pc as both the ps3 and my xonar essence st card have optical out so it would work just fine. Assuming there is some kind of device which does the whole switching thing? As for mic, I can live without for the ps3 and can just plug it into the pc, or split it to the pc and a separate cheap little USB adaptor for the mic only?
Second edit: on second thought sod it, I'll spring for the mix amp. But how does it get sound? Then how does it give the mic audio back? Would I have to get a USB switcher and an optical switcher?
paulst10
mixamp is optical for audio and usb for the mic.
RottenFox
For £100 you could pick up another surround processor and headphones...mixamp is way overpriced, IMO.
Same connections too, optical for audio, usb for mic.
And the Turtle Beach, and £2 usb cards sound like ****.
GuitarGuy
Could you reccommend? I'm after simplicity more than anything, Id rather just save up and keep it easy and sounding good. Was looking at the 5.8 and not fussed about battery because it'd be on my desk anyway.
RottenFox
GuitarGuy
Not really interested in the headset to be honest with you, might well just splash out on the mix amp.
paulst10
Personally I would keep the Sennheisers and add a Mixamp but it's up to you :smashin:
Shame no-one can confirm the DSS will accept pc headphones as that'd be the cheaper option
GuitarGuy
Yeah, I'll prepare to grab the mix amp but wait as long as possible to see if the dss can be confirmed to work.
paulst10
If you can wait until the weekend, I will grab my brothers DSS and try it using the Y splitter I got with the Mixamp to see if my headset works with mic :smashin:
GuitarGuy
That would be excellent, I'm in no rush. Could you also compare sound quality? Assuming you have a astro 5.8? If not I might try and find somewhere which demos them?
RottenFox
Won't work, you need the SteelSeries xbox adaptor, for a "pc" headset with the DSS, or a £2 usb sound card, and pc headset 3.5mm audio connection.
GuitarGuy
Well let Paul have a go anyway this weekend just to double check, then I'll just go buy the astro 5.8
paulst10
I have a mixamp pro.
GuitarGuy
Similar threads
Trending threads
Latest News
LG regards HDR10+ as unnecessary
  • By Andy Bassett
  • Published
Netflix US subscriber growth slowed by competition
  • By Andy Bassett
  • Published
LG Mini LED concept TV unveiled
  • By Andy Bassett
  • Published
LG Display to start OLED panel mass production at China plant
  • By Andy Bassett
  • Published
