Sorry to be a pest again but?
Discussion in 'Projectors, Screens & Video Processors' started by AV nutter, Nov 12, 2003.
  1. AV nutter
    AV nutter
    Hi guys pj at long last calibrated now i find that i have a thin line running right across the screen horizontal iam using comp out of my amp could the lead be at fault or is it just that the pj is so old thankyou all in advance. Av nuter
  2. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    This is normally associated with excessive top or bottom bow adjustment causing the converganece board to work extra hard
    BAck off your bow adgustment to see if it goes away.
  3. AV nutter
    AV nutter
    Thanks Rowland but whitch button is it on my sony 1020 no manual all try and error so far i have manage to get the colors bars top and down one side to give me something to work from as for the bow not 100% with you on that do mean the bow on all 3 colors or not. many thanks again for you help . mike
  4. helipilot
    helipilot
    Sep 20, 2001
    314
    Hamilton
    +19
    Mike,
    It is a long time since I had a 1020QM but from memory :-
    Bow can be adjusted on all three colours simultaneously or individually on Blue or Red.
    You will first of all have to determine which tube(s) the line is being generated by. Do this by displaying an image which clearly shows the line a white field is likely to be best. now switch off two tubes so that only the green is showing. similarly check the red and blue tubes.
    I have seen this problem on several 1020's. You may also want to shift the image vertically very slightly to see if that reduces the effect.
    In my case I think the line was on all three tubes but I was able to adjust it away. You may find that squeezing the image to get a 16:9 image can cause this effect as well. From memory the effect was much clearer at the left of the image than it was at the right.
    Check to see if the pots that control horizontal and vertical tilt are way off centre. If they are it could be that a yoke has been bumped on a CRT.
    You don't want to go anywhere near the yolks at this stage.
    P.S. you can download a manual here :-
    http://www.crtcinema.com/manuals.html
    It will not be for your exact model but will give some information that may help.
    Good luck
  5. AV nutter
    AV nutter
    Hi Alan bit late for me not going near the yolks but hell its turning into one nightmare no need to watch any films with this baby .I have managed to move the yolks screw that that i cant tight them up as i have lost them around the other side of the tube cant get a screwdriver in there to bring the back to tight them backup so you see my nightmare is getting worse than ever well the hammmer looking favorite i read somwhere that God loves a trier thats thanks for the info most welcome .mike
  6. Chris Frost
    Chris Frost
    Jul 14, 2000
    2,743
    Cheshire
    +107
    helipilot - FYI,
    The link to the page works but none of the pj manual links seem to work after that. Many of the other sites listing manuals for download have gone to subscription only transactions. A download typically costs $25 :( I guess it was only a matter of time before benevolence gave way to commercialism.
    Regards
  7. AV nutter
    AV nutter
    Thanks chris they only take creit card and i dont have only cash point cards not much use hell i find away .mike
  8. helipilot
    helipilot
    Sep 20, 2001
    314
    Hamilton
    +19
    Chris,
    Sorry I had not realised the links were down.
    Mike,
    I have the two most relevant pdf files. PM me if you want them.
  9. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
  10. AV nutter
    AV nutter
    Pj completed at 0645 today the wife hid the tool box me thinks no more fix that ant brocken off to see if i can get some zzzzzzzzz can all ways count PJS if i cnt sleep once again guys thanks for your help and support very happy bunny NOW.mike and family
