Sorry its me again!
Discussion in 'Home Cinema Control & Remote Controls' started by John Watts, Sep 26, 2001.
  1. John Watts
    John Watts
    Jan 27, 2001
    3,961
    71
    Leeds
    +80
    Sorry i took so long to get back to you,ive been on holiday. Now from your kind replies i gather prontoedit will help my cause,the only thing is i dont know what it is of where to get it so again if you guys can point me in the right direction ill try to sort this thing out (with more than a little help from you all) im sorry for bugging you all but i do need and appreciate your help so please stick with me untill i work it out<br />thanks again,John.
  2. Richard46
    Richard46
    Oct 15, 2000
    1,796
    63
    London E7 UK
    +120
    Hi John<br />You can get Pronto Edit and sample ccf files to get started and provide logos etc here<br /><a href="http://www.remotecentral.com/files/main.htm" target="_blank">http://www.remotecentral.com/files/main.htm</a>
    Good Luck Richard
  3. Doubledoom
    Doubledoom
    You don't want Prontoedit.
    I seem to recall from your previous posts that you have a Marrantz. In which case, you want RC5000 setup.
    Although it does the same thing, this version is only for the Rc5000/5000i
  4. Richard46
    Richard46
    Oct 15, 2000
    1,796
    63
    London E7 UK
    +120
    Thats right they are not compatible but Rc5000 setup also available at remote central
