Sorry Guys, can I ask a really, really dumb question?
Discussion in 'General TV Discussions Forum' started by the_sanguine, Aug 10, 2005.
  1. the_sanguine
    the_sanguine
    Jul 31, 2003
    1,176
    38
    +7
    Is the picture on a widescreen TV just a 4:3 picture streched (so that everybody looks fat) or do you actually see things at the side that wouldn't be on the screen of a 4:3 TV?
  2. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    5,864
    Galactica C.I.C.
    +279
    Not a dumb question at all :)
    If you watch a 4.3 image on a widescreen TV then yes, most Tvs have an option to stretch the picture. If the picture is a 4.3 one then no extra info will be seen on a widescreen TV.
    However most prime time (digital tv) is now in widescreen so it will look correct on a widescreen tv providing everything is set up correctly :)
  3. the_sanguine
    the_sanguine
    Jul 31, 2003
    1,176
    38
    +7
    I've just had a PDW7 installed as well as sky+.
    I've set the picture options on sky + to 16:9 and movies look great. However, some programmes like the football and news etc, everybody looks fat!
    I also found at first that the lip sync wasn't right but it seems better now.
  4. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    5,864
    Galactica C.I.C.
    +279
    This is because not every thing that is broadcast is in 16:9 widescreen. :)
  5. red16v
    red16v
    Aug 20, 2004
    552
    +5
    Hi, not a lot of people realise that technically speaking for tv originated material, widescreen (16:9) pictures and 'normal' (4:3) pictures are exactly the same width ! 16:9 pictures are reduced in height compared to 4:3 pictures and in order to get the 'framing' of the pictures correct the camerman has to 'zoom out' slightly - as a direct result you 'appear' to see more picture information at either side. Regards, yt.
  6. the_sanguine
    the_sanguine
    Jul 31, 2003
    1,176
    38
    +7
    I thought Stevie Gerrard had put on about 5 stone!
  7. per-Sony-fied
    per-Sony-fied
    Jul 24, 2005
    2,305
    +100
    Never watch a 4:3 programme in full screen 16:9 mode... it's silly and wrong.
    14:9 mode is a good compromise for a larger picture.
    In many respects it's still a good idea to buy a large 4:3 TV as the viewing area for widescreen programmes is greater than a equivalent widescreen set.
    You also have the bonus of a much bigger picture for 4:3 broadcasts.
