Sorry folks- Same old questions
Discussion in 'Plasma TVs' started by jblack, Mar 20, 2005.
  1. jblack
    jblack
    Mar 20, 2005
    28
    Hello All,
    The 5 year old box we've got has been playing up so we decided it's about time to take the plunge and upgrade. The logical upgrade seems to be a Plasma.
    I've spent the best part of 2 days stalking the forum and am at a total loss :confused:.
    With a budget of £1500-£2000 we need a package which will allow us to connect;
    Sky Digital box,
    Pioneer DVD player DV350
    Pioneer Amp VSX-C100
    PlayStation 2
    Our only other requirements are it has to be wall mountable and at least 42" and be good quality.
    The problem I think we may have is that the Amp has no SCART connections. Will this be a problem?
    Any ideas/suggestions?
    TIA, Jim
  2. SamirP
    SamirP
    Apr 28, 2003
    1,232
    South Of The River
    +32
  3. Mep
    Mep
    Dec 25, 2004
    9,532
    +468
  4. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +412
    With up to £2k to spend, might be easiest to go for an amp upgrade at the same time. It will save you complication, and probably not actually cost any more than other options. Have a look at Pioneer's web site for the VSX402, it has 3 rgb scart inputs, 1 output. For best picture, a JS VGA converter will do the biz, no input cards needed. I think in fact that will be about £1600. Connect to existing speakers, it'll blow you away.
  5. jblack
    jblack
    Mar 20, 2005
    28
    Thanks Guys,
    Decided on either a PW6 or 7.
    Would I be able to connect the Video/PS2/DVD/SKY+ to a 'Quinttro+RGB' then connect that to the 'JS Tech Converter' then to the screen?
    Cheers, Jim
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
