Sopranos - Digipack
Discussion in 'Shopping, Deals, Discounts & Bargains' started by CTT, Oct 26, 2004.
  1. CTT
    CTT
    Sep 3, 2004
    77
    Folks,
    I know that there is already a thread on the Sopranos, but started this new one in the hope of a quick response.
    Amazon are doing series 1-4 for 25.97 each, which is by far the cheapest that I have seen them. Few questions though what is a digipack? and does anyone know if these are widescreen or 4:3.
  2. Rob20
    Rob20
    Jul 3, 2004
    3,210
    +737
    I believe the digi-packs are all in 16:9. Having the original 4 sets, it was only the 1st season that was in 4:3 anyway. Hope this helps. If you want to be 100% sure just email Amazon.
  3. ruddles
    ruddles
    Are the r2 digi-pack versions better than the region 4 ones?
    cheers.
    Can you still get the first time customer coupons for Amazon?
  4. GavinBrowne
    GavinBrowne
    Jul 23, 2001
    237
    Edinburgh
    +4
    Thanks for the post.
    That's my Christmas sorted out!!
    Cheers,
  5. jont
    jont
    Apr 8, 2002
    4,298
    near Aylesbury
    +559
    IIRC it was only the R2 version of series one that was 4:3 ... the R1 is 16:9 ...
    Jon
