SOPNY DVD/CD "Juke Box" DVP CX985V (U.S.) Machine
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by 100949football, Mar 23, 2006.
  1. 100949football
    100949football
    Jul 30, 2005
    1,752
    48
    +39
    :hiya: Hi, recently acquired this brillian machine from U.S.
    Anyone know if it can be "backward" hacked - i.e. to play Multi-Region as it is currently a Region 1 NTSC machine?
    Would like to play Region 2's as well although it's not imperative as the machine is just fab!
    IT IS IN FACT A SONY - (A subsidiary of SOPNY!!!!!!!??????)
  2. Justin@UH
    [email protected]
    Feb 21, 2002
    2,194
    63
    Location location location
    +94
    Sorry, NTSC models cannot be hacked to play PAL discs. They are NTSC compatible only even if you modded it. You need a PAL model to start with to be able to play PAL discs (i.e European, UK R2, Australian R4 or Asian/HK R3 models).
