sony510 recording
Discussion in 'Blu-ray & DVD Players & Recorders' started by Churnobyl, Mar 25, 2006.
  1. Churnobyl
    Churnobyl
    Sep 22, 2005
    219
    swansea
    +5
    just a quick query about the sony 510 machine i am considering buying to replace my broken toshiba. does it have manually adjustable recording quality feature,or is it preset to sp,lp etc, the man incurrys didnt know,they are selling them at £299
  2. PhilipL
    PhilipL
    Jan 18, 2002
    3,855
    103
    +461
    I think you will find it is fixed recording rates, although not 100% sure.
    I would go for a Pioneer DVR-530, completely flexible recording settings, a 160Gbyte hard-drive and better editing facilities, also has GuidePlus and will control an external satellite or freeview box, for only a little more when bought on line.
    Regards
    Phil
  3. davuck
    davuck
    Mar 12, 2006
    Hi PhilipL, i have read a lot of your posts and seek a bit of your expertise, i have just bought Pioneer PDP 436 XDE and i am now in search of DVD hard drive recorder. With my set up, would it be best to try and track one down that has a HDMI connection as i do have 2 on the Pio 436 XDE or just go down the component route?:lease: What do you recommend?
  4. PhilipL
    PhilipL
    Jan 18, 2002
    3,855
    103
    +461
    There is no need for HDMI on standard definition and your Pioneer Plasma will do a better job at upscaling than most DVD recorders anyway so don't narrow down your options by having to have HDMI.
    If you have a satellite/cable box than the Pioneer 530/630 series will be a good match. If you are wanting to record Freeview then the Pioneer recorders will require partnering with a separate Freeview box which adds to the cost and adds another box to the collection.
    Your best bet may be to wait for the new Pioneer models with inbuilt Freeview. Panasonic also do good DVD recorders with Freeview built in, and again have newer models out soon so worth hanging on a month or so perhaps.
    Enjoy your plasma.
    Regards
    Phil
  5. ArtS
    ArtS
    Sony 510/710/910 have fixed recording modes only. There are 1/1.5/2/2.5/3/4/6/8h modes.
    ArtS :cool:
  6. Churnobyl
    Churnobyl
    Sep 22, 2005
    219
    swansea
    +5
    yes have checked them out pioneer 433mr for £250 533mr for £330, why did my nice toshiba have to break!
