Sony XH9505 & Laptop 'Flickering'
kungfupondfish
Hi everyone
I connected my laptop to my new Sony 49XH9505 tv via a HDMI lead, and the screen 'flickers' :-(. It gets worse when I go online on my laptop. My laptop is a HP brand, is approx 5 years old so is still really good. Is there something I should be doing in settings? I had no issues with my previous TV.
Please help.
Steve.
Eotyr
Have you tried flipping the signal format for the HDMI port?
settings - watching tv - external inputs - hdmi signal format
last i tried i couldn't get my laptop to display a full screen on the same set, no flickering though
kungfupondfish
Hi, I'll give that a go....when my fiancee gets off the tv :)
kungfupondfish
I have tried enhanced on the hdmi1 and there's no change.
Morden
Hi everyone
Please help.
Steve.
What mode are you using?
Morden
Hi, done that and its still flickering:-(
Have you updated your graphics drivers to latest available?
You could try setting tv as primary screen in graphics settings.
Have you set output to tv as correct aspect ratio, i would think 1080 as a minimum, but if your laptop graphics supports it try a higher resolution.
I had issues on win 10 on a non android tv and had to play about with output to get it to display correctly.
And I set tv as screen 1
kungfupondfish
Hi, thanks for the advice. I tried all those and it's still flickering. I didn't have any problems with my other TV.
AVForums Movies Podcast: We review Dune and ask which is the best decade for horror movies?
