Sony XH95 49" Wall Mounting Help
hansolo92
Joined
May 8, 2021
Messages
2
Reaction score
Points
Age
32
Location
London, UK
I just bought Sony KD49XH9505 TV, waiting delivery and trying to get everything ready so I can wall mount it straight up. Hoping someone could help. (My bracket is movable and TV will be turned regularly to either face my sofa or bed position.)
1) Does the 49" TV come with spacers ?
2) If yes, is it sufficient to use the screws already in the TV? Just take them out, screw in spacers, attach to mount, then re screw in those screws? (Please bear in mind I'll be turning the bracket regularly.)
3) If I need to buy new bolts please let me know exactly which ones to buy so I can have it ready before TV arrives!!!
4) The manual says 8-12mm screw space needs to be into the TV. Does that only apply if you are screwing directly into the TV? Because when you are using the spacers, then the spacers are in the TV not the screws? I'm a little confused here.
Would love to hear how you guys have wall mounted this TV.
Thank you so much for any information
Quality vs. Convenience: How do you consume your movies & TV shows?
Back
