Hi all, initially I set up the TV all ok including satellite connections Freesat.
I then set up some options with a usb device that I didn't like. I couldn't find a way to change the option back so I thought factory reset was the way to go. Oops!
When I got to setting channels on the satellite connection , it said I had no signal.
This was the same on Freesat setup and normal satellite setup.
I have 4 connections from my satellite, 2 into my Humax Freesat box for recording and 2 direct into my TV. The signal is fine to my Humax box, so I know my satellite is good. So I tried swapping cables from Humax box to my TV, to eliminate the cables into the TV being the issue, This gave same result on my TV, no signal.
So I conclude the factory reset has somehow stuffed my satellite function on the TV.
Help !
Help !
