Hi All,
I bought this TV just before xmas and I was doing a bit of dusting around the TV when i noticed the panel was flexing at certain points on the bottom of the TV were it meets the bezel also the two corners as well it just looks like a bad fit not very even. I can literally push really gently and it will set back around 1cm from the metal bezel - other areas are completely fine and firm. This can't be normal??
THANKS!
THANKS!
