SONY XE85 Picture set up
Farrenj100
hi all,
I need some help with my sony picture set up, I mainly watch movies and tv series in 1080p through plex, I also have sky q set up in UHD 10 bit. I'm not fussed about HDR hence why I brought the XE85. I have used the picture set up from this review Sony X85E (XE85) review - FlatpanelsHD.
Group Setting Value
Profile Cinema Pro
Brightness Brightness 8
Contrast 90
Gamma -1
Black level 50
Black adjust Off
Adv contrast enhancer Off
Colors Color 50
Hue 0
Color temperature Expert 1
Color space Auto
Live Color Off
Adv. color temp Red gain Max
Green gain -3
Blue gain -5
Red bias 4
Green bias -1
Blue bias -2
Clarity Sharpness 50
Reality creation Manual
Resolution 20
Mastered in 4K On
Random noise reduction Off
Digital noise reduction Off
Smooth gradation Off
Motion MotionFlow Off/Clear (Off for HDR)
Film mode Off
Video options HDR mode Auto
HDMI video range Auto
Color space Auto
I have changed the brightness to 13.
Black adjust to medium.
Adv contrast enhancer to high.
I'm just curious to peoples thought on this set up. I also watch a lot of sports but will probably just use the sports pre set
thanks for you help
Farrenj100
thanks for the reply, is that the same TV but US version?
I am very happy with the picture, I mainly use it with plex and all files play directly as opposed to my two year old LG that require constant transcoding. android works pretty well but if you have lots of apps open it does slow down to just remember to stop them not just back out of them
Podcast: Anthem AVM 70 Review, EQing Your Home Cinema Sound System and More...
