kjmsmith
I have a new xbr800e series and I am attepting to connect a Wii using the composite input. I had a 3.5mm composite RCA AV adapter on hand, yes the proper one as indicated by Sony (4 pole with video and audio left/right) and used it but the tv indicated there was no signal. I then tried attaching the Wii using the component input on the tv and it worked so that indicated to me the Wii cable was working. So I bought a new 3.5 composite plug and tried it but it too didn't work leaving me to believe the composite input on the tv is faulty. I hard-booted everything but no change. I googled this issue with little help other than reading someone else had the same issue that wasn't solved. Before I try to contact Sony or replace the tv I am wondering if anyone here has any advice or similar experience?
Thx!
Thx!
