Sony XBR
Discussion in 'Sony TVs Forum' started by bluepirre, Nov 29, 2004.
  1. bluepirre
    bluepirre
    Hi! Does anyone know if this model will work as it should in Europe (Sweden) were i live?
    Cause I´m pretty interested in buying this unit from US...
    Regards
  2. Blu Ray
    Blu Ray
    Jun 14, 2004
    496
    Chorley, Lancs
    +12
    I would be hesitant to buy a TV from the US. Apart from the voltage difference (110 rather than 220), their TV system is NTSC 60hz, and sweden is B.G. Pal 50hz. It may work just as a monitor, but I wouldnt risk it personally.
